Wheel Spacers
What wheel spacers are you guys using when putting on 285's vs. 265's?? Looks like it will hit at the top around the upper control arm...Also, I am worried about wear on ball joints and other parts with the lift/spacers??!!
I think Kregg used 1.25" wide on his 96 that I worked on Sat and he runs 35s.
https://www.yotatech.com/forums/f2/w...eekend-206926/ :guitar: |
You can get by using these cheapos with 285s:
http://www.wheelersoffroad.com/4runnerwheels.htm (scroll down to the bottom) I have 1" spacers and chose those because they are the smallest I could find that aren't the "slip-on" kind. I have heard the slip-ons can vibrate a lot, but they are dirt cheap! |
I only needed 1/4" for my 285's in the front.
Originally Posted by BIC performance
(Post 51393741)
spacers
guys i just need to understand one thing....... i got the OME882 for up front, i got the diff drop kit, and OME90004 Shocks, with this lift is it still recommened that i get some wheel spacers? i think the 1/4" would be enough, but i thought i wouldnt need them , could some one clear this up for me???
thanks |
Whether or not you need wheel spacers depends on what tire size you want to run.
Yeah forgot to mention that I will be putting on some 285/75/16AT tires after the lift..... So is the 1/4" spacer necessary??
What rims are you running? Because it really depends on the backspacing. If they are stock, most likely you'll need the 1/4"ers, but if they are aftermarket, you may need thicker than that or not need them at all.
For now I'm goin to put em on the limited wheels 16x7....
I would just get the ones I posted a link to in post #3, they're 5 bucks. It's just like guns - it's better to have em and not need em than to need em and not have em.
So if I can jump in here, I am looking to put a 3" OME lift with a 1" Toytec body on my 98 4runner and run 285/75R16. My wheels are the stock alloy yota wheels (16x7) will the 285's fit with just those 1/4" spacers then?
Thanks |
Originally Posted by brian2sun
(Post 51394908)
Spoken with true wisdom.... |
Originally Posted by yourrealdad
(Post 51395775)
Thanks |
(Post 51395775)
Thanks http://www.4crawler.com/4x4/ForSale/...BodyLift.shtml You don't necessarily need the BL either. With a little plastic fender liner trimming, hammering a couple pinch welds flat and taking my rear mudflaps off, I could clear my 285/75 M/Ts before I put the BL on - and that was with brand new tread. You'll probably have to do that stuff anyways, even with the BL. |
| All times are GMT -8. The time now is 07:25 AM. |
