YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   What is this wire? (https://www.yotatech.com/forums/f120/what-wire-314227/)
Mchendig Sep 28, 2021 08:29 PM
What is this wire?
I must have broken off the connector at some point…. Any idea? It is a California 4wd 89 pickup 22RE.
https://cimg1.ibsrv.net/gimg/www.yot...d7fe9ce9b.jpeg
it is the broken one I’m holding.
https://cimg3.ibsrv.net/gimg/www.yot...422b43e11.jpegDoes it go here??
https://cimg6.ibsrv.net/gimg/www.yot...d39f9b42c.jpeg
revsam937 Sep 29, 2021 03:39 AM
What color is the wire???
It would help a lot to know the color of that wire, and if it has a color strip on it (such as; white with red stripe). Also, it looks like your third picture is of your A/C compressor where the refrigerant hoses are attached. Could the wire be your A/C compressor clutch power wire? If you start your engine and try to turn on the A/C, but it doesn't run, then that's probably your answer.
Mchendig Sep 29, 2021 05:51 AM
Thanks for the reply. The wire is black with a white tracer. I can’t start it up right now, I have the intake manifold off.
Pixilated pixel Apr 25, 2022 01:44 PM
Wires
The other wire, is it green with red hashes painted on it? If so it is the cold start time switch. It is on the front of the block, below and to the right of the air intake on the manifold (facing the engine). There are two sensors there. The other one is to left and is the coolant temperature sensor.
