Weber water choke on a 22r
I was given a brand new 32/36 weber DGAV with a water choke. I bought the correct adapters from JT Outfitters and have installed the carb. Can I (should I) use the existing water choke? If so, where should I tie into on the 22r. Would it be better to convert to an electric choke and is this even possible?
You can use a water choke on a 22R, but an electric choke would be better imo. Here's where you could buy the choke http://www.webercarbsdirect.com/32_3...Parts_s/50.htm . If you wanted to stay with the water choke however, I would say that the best place to tie in the choke would be to go off of the heater hoses.
