Weber 36/32 Leak
I installed my weber several months ago and it is fabulous. I only drive my 82 once or twice a week, just beat and bang around in it. I had an issue come up a few days ago, did some research on here, asked some of my old school mechanic friends but unable to find an answer to my problem. I noticed my weber carb was leaking gas, after the engine was turned off but it does not do it every time. It does not leak while its running just after shut down. It appears to be leaking between the carb and the top plate. I have only put 300 or 400 miles on the truck since the weber install. Is this a common problem? Any ideas to what may be causing this?
Thanks JH |
