TRD 1st gen (grey) supercharger vacuum leak
TRD 1st gen 'charger has an L shaped by-pass valve assembly @ the left rear. It comes apart in 2 pieces after being unbolted from the main housing. There are 2 O-rings inside where the 2 pieces fit together, & where they slide into the back of the impeller housing. My check engine light trips showing a lean bank 1 code. A smoker revealed leaks @ the valve unit. I contacted Magnuson for parts but they no longer carry parts for the 1st gen.(tough luck for those of us still using the old, but faithful 1st gen). They did, however, offer to sell me a new generation 'charger! All I need is the 2 O-rings.
Has anyone else out there had this problem & found a solution? I haven't had much luck getting hardware store o-rings to fit properly. I've even tried sealing the O-rings & their passages w/ gasket compound, which worked for a while. I'm hoping for some help in finding a long lasting fix.
Thanks
Jim
Thanks
Jim
DesertRatliff
12-29-2017 07:25 PM
FS[FourCorners]: WTB: 1st Gen (grey) 3.4L Supercharger Parts
DesertRatliff
02-12-2016 06:37 PM
jdmaccord6
02-07-2010 10:02 AM
