YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Timing Chain (https://www.yotatech.com/forums/f120/timing-chain-166435/)
RustySchackleferd Feb 8, 2009 04:58 PM
Timing Chain
Is there is a difference between 1st gen and 2nd gen 22r
timing chain gears?
Toyota Pete Feb 8, 2009 05:46 PM
Yes 20R and early 22R were double roller chains. in late 81 or early 82 they went to single roller chain. You can install the double roller on a 22R up to mid 84. then they changed the deck height on the block and they all had single roller chains.
RustySchackleferd Feb 8, 2009 06:19 PM
so all the single chain gears are the same?
