YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Spark Plug (https://www.yotatech.com/forums/f120/spark-plug-131640/)
jcpe Dec 6, 2007 10:56 PM
Spark Plug
I Am Repacing The Spark Plugs On My 96 4runner. Spark Plug One Has An Extension Attached To It. Any One Knows What Its Called And Where I Can Get It ?
-MUDSLINGER- Dec 6, 2007 11:00 PM
its called when you pull the plug wire off and the crimp that holds the little metal sleeve no longer holds and it stays on the plug, I recon you should get new wires, as you should when you change plugs, and cap and rotor. have a good night.
Adam F Dec 7, 2007 12:45 AM
Mudslinger, he has a 96 4Runner, assuming V6, he has no cap and rotor and he has coil packs, located on the passenger side, and then one plug wire going to the driver's side.
Are you talking about the coil packs?
