reverse camera
I am trying to rig up a backup camera to an SPDT switch to come on when in reverse, but also be able to turn on the camera manually whenever I want. Does anyone have any simple diagrams or advice to help me? I'd also like to be able to do the same thing with a pair of reverse lights.
Backup lamps are switched power just tap them on the powered side and run it to your switch. For safety you could use that to trigger a relay..
Switch connector, center pin to cam, one side to fused power one side to backup circuit |
Originally Posted by Co_94_PU
(Post 52354223)
Originally Posted by Amos Elam
(Post 52354220)
...SPDT switch
For brighter lights, it's safer to use relay. Use the SPDT center-off switch to control the relay coil, power relay contacts from a fused wire directly from the battery, relay load output will go to your auxiliary backup light. |
reverse camera
If I am wiring up a reverse camera to an SPDT switch, with the ability to turn the camera on when I want (constant 12V) or with the reverse lights (acc power), what wires should I fuse? Do I need a fuse from the reverse light power to the switch? Is a fuse needed from the switch to a relay? The specific camera I have draws less than 1 amp. Also, is 18 gauge wiring sufficient?
Other thread here..
i merged your duplicate threads....
| All times are GMT -8. The time now is 12:26 AM. |
