Removing 3" BL question
I am planning to remove a three inch BL from my 94 4Runner that was installed by the PO, i know i will need to remove the spacer in the steering shaft, will i need to address the gas tank filler neck? are there any other hang ups i should look out for when bringin m body down. any input is appreciated
if it is an auto then there is a shifter bracket. also keep in mine if those bolts arent threaded the whole way you will wont to get shorter ones
it is an auto, would the fact that the indicator on the auto trans level reads incorrectley indicate the lack of use of a bracket by the po?
, i will be using completely new hardware |
As they say, "removal is the reverse of installation":
- http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml Bumper and radiator brackets, possibly shifter brackets, steering extension among other items. http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ11 |
Thank you for the links 4crawler
| All times are GMT -8. The time now is 01:45 AM. |
