YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Quick Suspension Question (https://www.yotatech.com/forums/f120/quick-suspension-question-235177/)
t3chth1rt33n May 12, 2011 08:29 PM
Sooo...cruising around the forums, I have noticed a ton of people talking about putting coils in the rear. But, In my 89, i don't have coils, I have leafs and shocks. Should there be coils there?
And the reasoning for this question: I have a bit of sag in the rear that I am trying to eliminate, but also try and get an inch or two of lift (thinking of putting 33s on). What would be the best way to do this? Ive seen 2 inch add-a-leafs on summit for around $50, but would those last? Should I just replace the shocks in the rear? OR can i add coils???
Help.
MudHippy May 12, 2011 08:42 PM
That's the reason for the coils. It's called a ZUK mod. You might also call it an AAC(Add A Coil). You essentially get lift/reduce sag.
See this link for the inventor's website.
http://gearinstalls.com/
There's plenty of good info there and elsewhere, including here, ad nauseum.
However you could also get the same effect by putting AALs or lift leaf springs on instead. I've had my 2" AALs for 4+ years and they haven't faded a nanometer.
t3chth1rt33n May 12, 2011 09:19 PM
Hmmm..interesting. But wouldn't leaving the old leaf springs there have negative impacts on the ride? And what kind of flex would I expect from this?
gary_the_4runner May 12, 2011 11:44 PM
use the search engine in the forum
type in ZUK MOD
tooooooo many threads on suspension especially on ZUK mods
not tryin to flame you, just sayin...
welcome to yotatech.
t3chth1rt33n May 13, 2011 07:31 PM
I proceeded to search but I still have two lingering questions regarding the ZUK mod itself:
1) What kind of flex would I expect to accomplish from this?
2) Has anybody had problems with not securing the bottom of the coil spring to the bumpstop? I mean by just putting the spring over the bumpstop, without any holder of some sort
rhill May 13, 2011 08:29 PM
1) better flex.
2) no.
t3chth1rt33n Sep 17, 2011 11:41 AM
And another one...Does anybody know a good place to get just lift blocks for it? All i can is full kits
Im just trying to weigh all of my suspension options
