pulling to one side when breaking hard
this may be a dumb question but i figured i would ask here before i spend any money trying to fix it.. a few months ago i had a locked up caliper so long story short i replaced the caliper and rotor on the right side and pads on both sides... do you think its just because everything is new on the right side so its pulling to the right? its not a violent pull just slightly pulls to the right ..should i just replace caliper and rotor on the left and it would even out? thanks in advance
Originally Posted by obxtarheel91
(Post 52426664)
this may be a dumb question but i figured i would as here before i spend any money trying to fix it.. a few months ago i had a locked up caliper so long story short i replaced the caliper and rotor on the right side and pads on both sides... do you think its just because everything is new its pulling to the right? should i just replace caliper and rotor on the left and it would even out? thanks in advance
if you have a braking pull it isn't just from the pads, as you now know replacing one caliper can cause a pull, I always recommend if you are going to replace a caliper or a rotor that you replace both. now you have one rotor that is thinner than the other and one caliper that is stiffer than the other. So one side grabs better than the other and one side gets hotter and fades out faster than the other (the one with the thinner rotor). |
Make sure you have bleed all the air out. Caliper replacement often requires a bit of extra bleeding.
Originally Posted by thefishguy77
(Post 52426671)
ok thanks im gonna get the other side replaced as well, I really appreciate the help
