YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   problem with ADD (https://www.yotatech.com/forums/f120/problem-add-167896/)
Joshua4507 Feb 23, 2009 03:19 PM
problem with ADD
I just bought a 1991 toyota because it has a 22 re and a five speed the down fall is the auto locking hubs are not locking in i suspect a bad switch the problem. but i don't know where the swich is located. is it on the t-case or on the shift lever?
any help is apreed :bang:
904_runner Feb 23, 2009 03:25 PM
does it have auto lockign hubs or the ADD
Automatic differential disconnect...
Is there a bunch of vacuum lines on the front diff?
Joshua4507 Feb 23, 2009 03:27 PM
how can you tell the differance?
waskillywabbit Feb 23, 2009 03:28 PM
This will help you see what is going on, not necessarily your solution:
http://www.4x4wire.com/toyota/tech/add/
Auto hubs and ADD are NOT the same thing.
:guitar:
Joshua4507 Feb 23, 2009 03:29 PM
yes there are vacuum line on the front of the diff
904_runner Feb 23, 2009 03:29 PM
EDIT" nvm
Thanks wabbit.
I had a problem with my ADD system, it was no longer getting vacuum to keep the shift fork locked, which wouldn't allow the front wheels to put the power to the ground.
I ended up bypassing the VSV's and ran a vacuum line directly from the ADD shift tube to the engine, this kept constant vacuum on my shift fork.
Before that i added manual locking hubs so i could unlock them and not have the cv's spin.
If you are going to do this you will need manual locking hubs.
waskillywabbit Feb 23, 2009 03:31 PM
Auto hubs were 84-89 only I believe, so he has ADD.
Some more info:
http://www.4x4wire.com/toyota/tech/autohub/
:guitar:
toyota4x4907 Feb 23, 2009 03:31 PM
Werent auto locking hubs phased out/replaced by ADD in like '87..'88 or so?
so it has to be ADD :)
EDIT: Wabbit said it before i did :)
Joshua4507 Feb 23, 2009 03:35 PM
in my eyes the cure would come in the form of a solid axle swap. but untill then i want to see if i can make what i have work. also my 4 wheel drive light does not come on. any idea where the swich is ?
904_runner Feb 23, 2009 03:37 PM
Well when you throw the TC in 4wd it sends a signal to the vsv to creat vacuum.
Your light will only come on if that shift fork is locked
Joshua4507 Feb 23, 2009 03:39 PM
is there a switch that is trigered when you put it in 4 ?
4Crawler Feb 23, 2009 04:33 PM
Yes:
- http://www.off-road.com/trucks4x4/ar....jsp?id=399612
Joshua4507 Feb 23, 2009 05:01 PM
thanks for the help. now i understand my truck better. and what i need to do next
