Sponsored by: CARiD
ordered new 22re, any performance suggestions?
Old Nov 4, 2006 | 08:07 AM
Cbass's Avatar
Hi, i bought a 90 4runner about 2 months ago. It has 203,000 miles on it... I cracked the head the other day and just decided to buy a new longblock today instead of replacing the head... I got an orient engine.... my question is, what are some things i can do to get a little more performance out of it..... the motor that was in it just didnt cut it.... 4 hi was almost unusable due to the lack of power. Im looking for fairly inexpensive ideas. thanks in advance. Clay
Old Nov 4, 2006 | 08:55 AM
EWAYota's Avatar
you can dump a ton into it and its not gonna be a rice burner, ever.... easiest things to do, get a new cam, headers (search for 22RE headers for ideas) and 2.25 exhaust with a high flow cat and do the deckplate mod (you can find that searching that exact term).
Old Nov 4, 2006 | 09:01 AM
Cbass's Avatar
Thanks for the advice....
Old Nov 4, 2006 | 11:07 AM
dcg9381's Avatar
You're limited to bolt-ons now that you've purchased the motor.
Header (as mentioned above) is probably the best bang for the buck.
Other cheap options are to remove the mechanical fan (go electric), a mild cam, and slightly advance the timing.
Old Nov 4, 2006 | 12:59 PM
Elton's Avatar
modded stock airbox Lce header hiflow cat 2.25'' exhaust all the way back and a cam of your choice that should help
Old Nov 4, 2006 | 01:15 PM
Cbass's Avatar
Thanks guys...
Old Nov 4, 2006 | 03:36 PM
AH64ID's Avatar
First off, 4hi is pretty much useless on a fresh 22RE. Its more of a high speed 4wd, where anything slow requires 4lo..
As far as mods, I would do a Trueflow airfilter, LCE exhaust, magnaflow 2.25" cat, Flowmaster 2.25" muffler..
Your best bet for a little more hp will be a cam and O/S valves. If you really think it necesscary I would see about just getting a short block.
Nothing is inexpensive, and nothing will make a HUGE difference. Even with a 10% gain in useable power you only talking a 130hp motor.
Old Nov 4, 2006 | 05:17 PM
crackerjack's Avatar
I like my JET chip too
cars-guy
Aug 16, 2020 06:59 AM
May 20, 2016 10:27 AM
Sep 4, 2015 09:27 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
