Is it okay to use lug centric wheels on hub centric wheel spacers?
Lately, I've been looking at some Spidertrax wheel spacers to widen my stance.
However, my wheels are lug centric and the spacers are hub centric. Would this cause any problems either immediate or in the long run? Thanks. |
yes its fine. When i worked in the tire/wheel industry we would use hub rings with most aftermarket wheels to make them hub centric as well as lug centric. Just make sure the center bore of your wheel is large enough for the lip on the spacer. If not you could always grind the spacer down and it would just be lug centric.
