O2 Sensor 4 wire female plug#
Since it seems no one has any plugs they want to sell
I can`t find the number on mine at least the one that is still there. Does anyone know it?? I have looked on all the Toyota online sites but they are not detailed enough. Again the 4 wire female O2 sensor plug Which is on the harness side. Thanks :fire2: |
I noticed the plug and harness is completley missing on my 85. I will be in the boneyard in the next couple of days. I will keep an eye out for an extra plug or part number. Might be a couple of days.
thanks I do appreciate it
I will check my 3.0 that I'm parting out.
Thanks!!!
I guess not many people look at the wanted section |
I made it to the junk yard and the only truck that would of had the part was completely stripped. Not sure why they still have it as there just isnt anything left on it. They have two 3rd gen Runners and a 4th gen truck. Pickens are slim in my area. I am going to another yard next weekend so will look and see if anything is there. Didnt want you to think I had forgotten.
Do you know if a 3.0 would interchange or atleast have the same plug? The next yard I am going to has a 2nd gen runner with a 3.0., an 88 pickup 3.0 and a 79 truck 22r with just a rusted frame and what is left of a cab, front end has been cut off. |
Yes from what I hear all the 4 wire O2 sensors plugs are the same.
I have not seen for myself . Thanks again |
In case anyone else has this issue The 4 wire plugs are not the same across the years .
The plug from the 2000 Tacoma will not plug into the connector from the 97 4Runner Harness go figure . So now having a number from the new 97 Harness I ordered two connectors because I have pigtails from bad O2 sensors that will fit. In case anyone wants to know the connector # for a 97 4Runner 3.4 O2 sensor is 90980-11028 |
