no atf temp sensor
Hello there im new to this board i live in Suriname (south america) i recently bought a 96 2wd sr5(has limited badges) "bought it that way" and i have a problem i have a check engine light and pulled the code p0710 "Transmission Fluid Temperature Sensor Circuit Malfunction" i searched under the car but cannot locate the sensor i already looked in the service manual but its not where the manual says it should be the previous owner told me that he had changed the tranny a couple of months ago so could it be that this tranny doesnt have the temp sensor?
and is there anything i can do to keep the check engine from lighting up(a fix to not show this code)?? thanx in advance |
You could try putting a resistor in place of the sensor and reset the computer and see if the light goes off and stays off.
Originally Posted by myyota
(Post 51539059)
thanx would never have thought of it |
