YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Need help, where to start!! (https://www.yotatech.com/forums/f120/need-help-where-start-166834/)
erikp18 Feb 12, 2009 11:02 AM
I have a 2000 V6 4Runner sport 4x4 with 90k on it. I will be driving it approx. 20k miles per year mostly highway. I occassionally will pull a small snowmobile trailer. After reading alot on these sites I am planning on putting a lift in it and bigger tires or wheels and tires along with the removing the elbow in the airbox and doing my 90k service including new plugs, changing all fluids, timing belt and water pump. I am soooo confused about what type of lift to put on it. I don't want to spend alot but i would like some lift, maybe a bit softer ride but with stability still around corners. I will seldom be going off roading but through dirt roads and snow covered areas often. I am not sure where to even start..... Please help
thanks
waskillywabbit Feb 13, 2009 01:49 PM
Welcome to Yotatech.
I moved your post to the appropriate forum area.
:guitar:
Dirt Master80 Feb 13, 2009 02:03 PM
mild lift.
I keep it simple and small. See what coil spacers you can find they will keep you rig driveing good and give you the mild lifted look your after. This is also likley the cheapest. Good luck
