my baby is stalling and it isnt the MAF
1 Attachment(s)
So, ever since I moved down south I been doing a lot of driving, I realized my 94 4runner keeps stalling at idle when Im at stop signs and stop lights or turning,its like im going 2mph than it regains speed after pressing my foot down all the way on the gas pedal, I recently replaced the alternator, the spark plugs and wires, my belts, fuel filer, my rotor button, and my battery, I also cleaned my MAF, but nothing helps its still stalling n theres no engine light coming up, what could be the issue i need advice, I'm bringing it to the shop tomorrow cause my diy tricks all failed. |
Is it throwing any codes? check engine light? hot idle or cold idle?
no engine light, hot idle
Next i'd look at the throttle possition sensor.
it could be that cause it jerks when regaining speed
Vacuum hose leak? Dirty air filter?
air filter is clean; but it cant be the tps if the engine light isnt coming on
Originally Posted by iheart94
(Post 51927429)
ill check in the am since autopart stores just closed.
you need a multimeter and some feeler gauges to make sure its withing spec and adjusted properly. Link to help
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml |
(Post 51927405)
