YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   MSD Ignition (https://www.yotatech.com/forums/f120/msd-ignition-167126/)
89OldBlue Feb 15, 2009 09:35 PM
MSD Ignition
So I know this is kinda a stupid question, but what does an aftermarket ignition do for you? Is there another element that is works better when the upgrade is made?
Call me stupid, cause I dont know much
muddpigg Feb 16, 2009 12:00 AM
I've got the Summit (mallery makes it I believe) jst a newer generation, digital. MSD is analog. I think it gives a little more low end torque, a little. For the price not worth it in my book.
You'd probably get more from an electric fan but in saying that I'd go with the Tuarus or other actually OEM over an aftermarket like flexolite. JMHO or $0.02 if you will.
surf4runner Feb 16, 2009 04:03 PM
MSD = multi spark discharge. you get multiple sparks vs a single spark.
only better if the rest of the system is taking advantage of it.
desertcox05 Feb 17, 2009 05:59 AM
MSD= May Suddenly Die if you by one keep the stocker with you as a back up.
Belize Off Road Team Feb 17, 2009 09:01 AM
It would be best to find a whole bunch of reviews of people who have used MSD before making your choice. MSD is good for vehicles otherwise why would classic car builders use MSD for their ignition for many years now? Similar to K&N, it is all on how it is used and abused.
muddpigg Feb 17, 2009 11:05 AM
I jacked up a tow strap pulling a samuri off a mountain trail when his die. He didn't install it and had no idea how to bypass it. Said he'd replace my strap but didn't.
89OldBlue Feb 18, 2009 09:37 PM
ok, but what does the actual ignition do when upgraded? do i get more hp? torque? and I mean with any company, summit MSD, whatever.
muddpigg Feb 18, 2009 11:16 PM
I'll say yes but not much and from my experience I'd say put the money elsewhere. You just not going to get the gains they claim.
I'm running summit ignition box, accel hi volt coil, 8mm wires, forget spark gap though.
surf4runner Feb 19, 2009 09:15 AM
:banger: LMAO!
i have it installed in my datsun 510.
def spend the money elsewhere!
