YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   missing link (https://www.yotatech.com/forums/f120/missing-link-188884/)
islandboyjt20 Aug 12, 2009 09:08 AM
missing link
have any of you guys did a missing link set-up on a yota...
or what do you guys think about it...i am allright fabing stuff togther...gust wanna hear about it befor i start buliding...thanks...:coffee:
tc Aug 12, 2009 10:14 AM
WTF is a missing link setup?
I've heard of 5-link, 4-link, 3-link, y-link, all kinds of stuff, but never heard that one.
I did a dual triangulated 4link for the rear of my 4Runner ... came out well
4Crawler Aug 12, 2009 11:42 AM
Is that the double shackle setup:
- http://www.rocky-road.com/zuklink.html
If so, most folks find there are better solutions on the Toyota, notably longer springs. Double shackle may be viable if you have very short springs, like on a Zuk, and have no other option, and can live with their drawbacks.
islandboyjt20 Aug 12, 2009 09:15 PM
missing link
has anyone did a missing link on a yota...i am thinking about doing one and would like to know what you guys think about it...i have one on my sami and love it. it has alot of flex...i am thinking the same with my yota...(lots of flex sounds good) do you guys think it will work good...i started the project but now think about it more...
Tofer Aug 12, 2009 09:22 PM
missing link??
seanmearse Aug 12, 2009 09:46 PM
This a missing link.
scuba Aug 12, 2009 09:46 PM
is this one of those patent pending things...?
:dj:
seanmearse Aug 12, 2009 09:54 PM
Couldnt tell you. I just saw it, then Googled it. The whole "off road use only on front end" is kind of sketch.
islandboyjt20 Aug 12, 2009 09:57 PM
its an extra shackle attached to the top of the original shackle that allows the axle to drop even more...its common on the suzuki's here a link...
i think i am going to do it what i here is that no one did it on a toyota...so i guess ill try...:dunno:
Tofer Aug 12, 2009 10:01 PM
got it... NO idea why it would be called a missing link.... when you ADDING something.. yes, it can be done, i have it on mine and i love it.
as seen here
http://photography.eakland.net/d/833...f+DSC_3480.JPG
i've always heard of / known it to be called a double or scissor shackle set up
islandboyjt20 Aug 12, 2009 10:04 PM
well i think that if you can pin it up and not let it drop when driving on the road it would be okay...we did a missing link on my sami and it does exelent in the trails...
islandboyjt20 Aug 12, 2009 10:07 PM
as seen here
How long is your top (drop) shackle?
i am thinking about making it kinda of long to get more flex...you think it will work...
tc Aug 13, 2009 07:04 AM
Flex, especially dirty hooker droop flex is overrated.
It looks impressive as hell in pictures, but there is no spring force driving the axle down to provide actual traction. The ONLY think it is good for IMHO is to "catch" the vehicle as the weight coes back over to that side to have a more controlled descent instead of just "falling" and then having shock damping.
Tofer Aug 13, 2009 07:24 AM
i like my dirty hooker droop flex......
Tofer Aug 13, 2009 07:26 AM
the top shackle is the stock Chevy shackle....i can get meausrements today, but i would guess its 3" eye to eye
tc Aug 13, 2009 09:31 AM
Note that "dirty hooker flex" is indeed a technical term the desert guys use to describe a lot of poorly controlled articulation - usually in reference to the Ford twin beam suspension that dramatically changes camber angle as the wheels travel, frequently causing them to hook an edge when the suspension is drooped.
islandboyjt20 Aug 13, 2009 10:51 AM
their is still traction with thees...not as much as coils but it can go about the same places coils can...(and maby more) haha... hay and thanks Tofer for the pic and info...and what kind of springs do you have on that 4 runner...by the way its nice...
islandboyjt20 Aug 17, 2009 06:51 PM
i have pic of my missing link...the shocks are not mounted yet but they will be soon...i just wanna know if anyone wants to see them...thanks guys who responded...
91 4Runner Aug 18, 2009 04:52 AM
Sure, who wouldn't. Just because this setup isn't for everyone doen't mean someone might not like it/get ideas from it...
islandboyjt20 Aug 18, 2009 02:03 PM
pic
http://i105.photobucket.com/albums/m...8/DSC03957.jpg
cut um to size
http://i105.photobucket.com/albums/m...8/DSC03961.jpg
notch um
http://i105.photobucket.com/albums/m...8/DSC03962.jpg
weld um...i used 2inch heavy duty spacers...
http://i105.photobucket.com/albums/m...8/DSC03966.jpg
paint um green
http://i105.photobucket.com/albums/m...8/DSC03997.jpg
made new shackles one n a half inch longer than stock...
http://i105.photobucket.com/albums/m...8/DSC03990.jpg
they work kinda good...hay i got a open diff and a broken front end...(2wd...now if only i had a str8 front...)
http://i105.photobucket.com/albums/m...8/DSC03999.jpg
some creepy creeper joints would be good in hear...
http://i105.photobucket.com/albums/m...8/DSC04002.jpg
the front tire is not tucked in...i never lift the truck from the a arm...
http://i105.photobucket.com/albums/m...8/DSC03996.jpg
ten inches eye to eye...
what do you guys think...
i will try to get a video as soon as i put my motor back togther...doing a rebuild of the 20r that was put in by the previous onwer...go figure...:roll:
