YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Fuel pump? (https://www.yotatech.com/forums/f120/fuel-pump-129559/)
my4runner Nov 11, 2007 02:27 PM
Fuel pump?
Ok my friends, I messed up something...I was running a diagnostics, just to see if everything was good..I must of touched the wrong connectors on the diagnostics, now my 4runner wont start, I checked the fuel pump, its not getting any power, I took the fuel pump out, checked it running jumper wires to the battery, its workin just fine, so, there is no power getting to fuel pump, any ideas??? Thanks....:bang:
Bigblock Nov 11, 2007 02:29 PM
What two did you jump?
DeathCougar Nov 11, 2007 02:42 PM
Well one might check fuses if he wasn't getting any power....including the high amp fuses....
DeathCougar Nov 11, 2007 02:43 PM
Also, check the circuit open relay (pass side dash area bolted to middle of "a" pillar)
tampabayota Nov 11, 2007 02:44 PM
x2 on the fuses
my4runner Nov 11, 2007 03:05 PM
Thanks for the replies, I checked all the fuses, but have herd of a possible relay, just dont know where the relay is....I dont remember the where I jumped the wires on the diagnostics, thanks
