Engine block warmer
i have a v6 3.0 EFI 89 runner, what engine block warmer should i get??
or should i just get a blanket??? wanting it for cold starts |
A block heater for an '89 3vze....
Originally Posted by toyota4x4907
(Post 52031531)
sub'd :) I was thinking about this today
They run hot and only take seconds to warm up in the morning. Shouldn't need one ;)
Originally Posted by MaK92-4RnR
(Post 52031554)
(Post 52031554)
Originally Posted by Luvmy89
(Post 52031551)
yes sir, 3.0 efi v6
Originally Posted by 85gijunk4x4
(Post 52031560)
true that, used to take my 22r and 22re a LONG time to warm up, let alone hit its peak temp. When I start my truck in the morning (its been in the teens here as well) i'll let it run only 3mins or so, and the needle is in the middle and stays there for the rest of the drive :D
(Post 52031565)
No, I am saying all you need is a "block heat for an '89 3vze".
(Post 52031568)
but that initial start in the morn is very rough
Whatever brand is available at your local auto parts store. If not there, whatever you can find online. I have never heard of anyone saying "OMG This so-so-brand block heater sucks! buy so-so-so-brand or live the consequences!"
I think the real question is wich kind to go with. I know there is the dip-stick kind, which seems like a pain to me...and the oil pan mat thingy one....and I'm sure plenty more.
just searched autozone, not sure if there any around you, but they have such a variety of heaters...pretty reasonably priced too. Might pick one up soon if the weather stays like this
To me, an "engine block heater" is the freeze-plug replacement type. It is tghe only type I know and use. I have heard of the dip-stick kind but thats for oil, AFAIK. Never used one. I have never heard of anyone using them here, as is.
Here we use the in-block style like I mentioned earlier, along with an oil pan pad, a battery pad or blanket and a transmission pad. |
i looked into this.
The block type that go in a freeze out plug can be a little difficult to install for the average person. Unless doing the install during a engine rebuild. It looked to me the most simple would be one that goes in the lower radiator hose . I know that Kats makes good engine heaters Using any heaters going into the coolant always disconnect the electric before cranking. |
thanks guys i think i know what i will go with now. :banger:
| All times are GMT -8. The time now is 10:43 PM. |
