Elocker...8" to elocker housing
I know the 8" housing can be modified to accept the elocker, but I have never seen it ever mentioned if you can throw the regular 8" rear on an elocker housing. The reason I am wondering is my yota is being taken for recall. But I would like that elocker yet dont want to swap the whole axle. I think keeping the same wms and all would actually be easier. The r&p is the same so for the most part easy.
Opinions and answers thanks.... |
I was looking at doing this to test out a gear ratio. I think you can I'm not sure about being able to seal it up good, and you'll want to drill and tap the 2 relocated holes so that you're only minus 1 hole at the 3 o'clock position. If it is only to take it to the dealer for turn in? To be honest swapping the whole axle would probably be easier.
well the axle is also ABS...not sure if it matters.
