electrical problems with 88 2wd 22R
I have a 88 22R 2wd.The truck will turn over but will not start up.It is not getting a spark at the plugs.I had the alternater rebuilt,have put new wires and cap and rotor on it.I changed the computer or control module in the passenger side kick panel.I have changed the coil and Igniter but maybe the used/new one is bad.Does any one know which wires from the distributer,coil,igniter, should have power and how important it may be to test how much power.Also any suggestions as to why this truck wont run.
Originally Posted by joecool76
(Post 51984773)
You called it a "used/new" one. Is it new/new or used/new-to-you? The other ignition related component is the Signal Generator/Pickup Coil" in the distributor itself. You'll need to test that as well.
(Post 51984773)
(Post 51984773)
That will get you started until others can chime in. |
