Drivin' a turd
I have a 1991 pickup up with the stock v6 3.0. I recently put some 33" BFG all terrains on it and now i notice the lack of horse power and mpgs...what can i do to improve my mpgs and hp??
Put in some different gears
go back to 28's or 29's. change the gearing run nos :D
Case closed :facepalm:
Change the gearing and/or font size!
Really though you could probably do a search and get the answers you need.... |
check engnbldr get another head or have yours machined, change the gears front and rear, add a sneaky pete bottle of noz . when you have to go up hills hit go baby go. and dont forget the exhaust side.
Start with a 30hp ebay chip, a electric supercharger and a tornado fillter. After all that should be equal to a corvette in 0-60:great:. You can either swap in new gears or put the smaller tires back on.
Put 35's on it.
Originally Posted by 94toy22re
(Post 51897166)
I couldn't decide wether to cry or choke with laughter after reading that. Like pretty much everyone suggests, gears. You could aim for some cold air intake setup and sure the dramatic head work, but the easiest thing that would give you the most results would be gearing, because that 3.0 is not going to spin those tires no matter what you do, unless you're in 4L without the front hubs locked :nana: |
Thats not true. My 22re smokes my 33s all day booooooyyyy!
Man everyone is just too quick with the sarcasm! not even giving me a chance :nana: btw You could swap in a pruis motor and get a coffe can muffler :stir: |
Depending on the gearing, and maybe if he has a 5spd and dumps the clutch I could see it, otherwise, my experiences, no. /notsarcasm
make sure the engine is tip top and check it for codes. if a 4 cyl can handle 33's ur v6 probly needs a little tuning/sensor replacement. my 2 cents.
a simple tuneup might add a few ponies... my 4runner had 31s stock and ran rough. I got used to the slowness in no time... eventually I swapped to 33s and did a tuneup at the same time. Felt exactly as fast as before lol. A valve job was included in the "tuneup"
Scrap the 3.junk and buy a 22 r or swap with it for a v8.
Originally Posted by Junkers88
(Post 51897121)
(Post 51897166)
Check to see if your muffler bearing needs replacin'. If that don't work, it's totaled.
:jk: |
POoP ThReAD!
hahaa the good old muffler bearing.
