YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Double nut method.... Now what? (https://www.yotatech.com/forums/f120/double-nut-method-now-what-313895/)
Darylzane Aug 4, 2021 04:47 AM
So I used the double nut method thinking that I was going to be installing a Weber but that changed and I'm now back to a OEM but I now no longer have a I don't know what to call it actually double-sided bolt to mount with what exactly am I looking for what do I call it and where can I get one obviously at Lowe's or something like that since AutoZone is not opened this early but I tried to use a whatever one that was only single-sided and it just fall right through so what exactly do I do to actually mount the carburetor? I mean I suppose I could use super glue with rubber cement or I don't know a rubber band. But really what are those called exactly?
https://cimg7.ibsrv.net/gimg/www.yot...e06ebc35df.jpg
I used high tech and gasket sealant I'm not sure if that was the right stuff because I also heard you're supposed to use white lifting Grease so any advice would be appreciated and that's not going to be the only question I have I'm also going to need a lot more help as far as I'm pretty much the rest of it
wyoming9 Aug 4, 2021 08:48 AM
I think what your trying to ask is you need studs to mount your carb
M8x1.25 I would guess overall length is around 40 mm just a guess depends how thick the flange on the carb is
