YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Door locks (https://www.yotatech.com/forums/f120/door-locks-139069/)
sleaz22xx Mar 4, 2008 06:21 AM
Door locks
94 runner sr5 has an aftermarket alarm system that includes the automatic locks, My battery is dead to the point where i cant unlock the door with the keyless entry remote, my doors will not simply unlock with the key, when i try it feels like the key will break, is there somthing im missing here, am i about to smash a window to get into my runner?
Thanks
sleaz22xx Mar 4, 2008 06:24 AM
is there a way i could get the hood poped with out using the lever in the cab?
so i can get some juice to the battery and then hit the keyless entry remote? thanks
sleaz22xx Mar 4, 2008 06:49 AM
COuld it just be a worn key that wont allow me to open the locks from the outside?
Psalm 112 Mar 4, 2008 06:53 AM
I'm assuming that you've tried each of the locks. I have not heard of a way to get the hood to open...
sleaz22xx Mar 4, 2008 06:58 AM
And just as quickly the problem was solved, the lock cylinders must have been seized up from lack of use due to the keyless entry, I just sprayed a bunch of PB blaster in both keyholes, and got the driver side to open with the key.
WSUWESTON Mar 4, 2008 07:09 AM
I had this happen on my car, I sprayed graphite on my key and then worked the lock for a min and it opened right up.
Psalm 112 Mar 4, 2008 07:20 AM
like magic!!
