YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   code 52 (https://www.yotatech.com/forums/f120/code-52-a-202326/)
BIGRED60 Jan 24, 2010 03:54 PM
code 52
:horse::gijoe::horse:1991 4x4 ext cab 3.0 v6 has code 52 knox sensor code. Has a new sensor and harness still has same code.
yotaneck13 Feb 21, 2010 08:13 AM
try clearing the code and reseting if that doesnt work pull the knock sensor and clean tho hole behind it out
BIGRED60 Feb 21, 2010 04:45 PM
Do you mean to claen the hole under it this is a v6 so the knock sensor is under the intake. Not tring to be smart a-- but I just want to make sure that I understoud you
