YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   Bending, without bender? (https://www.yotatech.com/forums/f120/bending-without-bender-240735/)
slowngreen Sep 2, 2011 09:57 AM
Is there any way of going about bending tubing, without a bender and not actually kinking it?
Any advice would be awesome. I want to do some cage work on my truck but cant afford a bender. All I have is a torch and vice's.
creswellhick Sep 2, 2011 10:03 AM
i heard you can fill it with sand and tape off the ends that helps it from kinking
waskillywabbit Sep 2, 2011 10:18 AM
To build a cage.
Hell but no.
:wabbit2:
BMcEL Sep 2, 2011 11:13 AM
Depending on how many bends you need, it probably wouldn't cost much to have a shop do them for you all at once. You would obviously need to know quantity and angles but it's an option. Do you have a welder?
shakes_24 Sep 2, 2011 11:19 AM
wabbit is right on the money... not gonna bend .120 dom with a vise and torch. well not nicely anyway :D
greencactus3 Sep 2, 2011 11:22 AM
for some things yes, for a cage, no way
xxxtreme22r Sep 2, 2011 11:34 AM
x2 or is it 3? Nope your not gonna bend .120 dom without a hydraulic/pneumatic bender. Just isn't gonna happen.
snobdds Sep 2, 2011 11:57 AM
I've seen a person use a conduit bender and a lot of heat to bend DOM. He was only doing a 90* angle bend so it wasn't much. It came out decent, I could not tell he didn't use a bender. If its just a couple of bends here or there then do what you have to do to make it work.
If your bending a lot of stuff, then it's a no brainer, get a real bender.
waskillywabbit Sep 2, 2011 12:26 PM
Trying to build an exo or cage without a bender...
...you'll have better luck nailing jello to a wall.
:wabbit2:
slowngreen Sep 2, 2011 12:29 PM
Ok thanks guys. and Yes, I have a welder. I just wondered if there was any "tricks" to doing it without. I'll look around for a shop locally.
xxxtreme22r Sep 2, 2011 12:45 PM
:lof: That is completely possible. Here's proof: http://www.myscienceproject.org/j-wall.html
shakes_24 Sep 2, 2011 01:00 PM
:wabbit2:
that is hilarious ... it may be possible but the quote just sounds great.......
BMcEL Sep 2, 2011 01:15 PM
It should read 'you'd have better luck nailing jello to a wall without ramen in it.' :hillbill:
drew303 Sep 27, 2011 12:03 AM
LMFAO!
theres actually a website dedicated to how to nail jello to a wall... wow :bllama:
and no, dont bend without a real bender.. SAVE YOUR PENNIES and buy one! or make one... or pay us to build your cage.
IngSoc Sep 27, 2011 01:57 AM
BWahahah on the jello. GTFO.
rcrandy Jan 23, 2012 03:16 PM
I know a guy that builds his own dune buggies he uses three trees in his front yard to bend his tubing. Seriously!
NH Mudder Jan 23, 2012 03:28 PM
Yes, so plant 3 trees in your front yard and wait a few years and you'll be good to go! :) lol! Just kidding.
treyota Jan 24, 2012 12:04 PM
Harbor Freight has got a bender for under a $100. A tubing bender is one of those things that is a good investment; when you need it, you NEED it! Nothing else will do. Not even a tree! lol!
waskillywabbit Jan 24, 2012 12:09 PM
HF sells a PIPE bender that is a POS. Tubing and pipe are NOT the same thing.
:wabbit2:
treyota Jan 24, 2012 12:20 PM
I didn't say I bought one. But they do have a 12 ton bottle jack bender. No idea if it works or not...
