98 4runner RPM Gauge stopped working
Hey guys, this is my first post... I've looked EVERYWHERE and can't find an answer to my problem. That being said, I recently changed all my gauge lights to leds (all of them including the P N R D 2 L lights) and I've noticed some issues. First, my battery light and cruise control light stay half lit all the time, even with the lights off. And after I put the cluster back in , the RPM gauge won't work at all. I also noticed that now my check engine light is on all the time (this is a first). And ideas? and by the way, I have checked the main connections to the cluster multiple times.... thanks!!
Hey, I figured out the problem.... There is a small plastic cover that goes over the plug in for the RPM gauge, and when I put it back on it wasn't allowing the the screws to act as grounds for the gauge. Also, the led that I installed for the R light was not manufactured properly (continuity between the leads) causing my engine light to remain on....
Originally Posted by maD:Max
(Post 51982632)
