95 2nd gen wheel bearings ?
Old 03-31-2018, 05:56 PM
jbslash25's Avatar
Is it a good idea to change the snap ring on the spindle of a 95 4runner when changing the wheel bearings. If so where can I buy them
Old 03-31-2018, 07:40 PM
thefishguy77's Avatar
I reused then in the front end of my 93 pickup 4wd with no issues.
Old 03-31-2018, 07:42 PM
wyoming9's Avatar
Red face
Only if you destroy it trying to remove it.
If you had a bearing failure and it is damaged from the heat and your also replacing the hub .
Any Industrial Supplier or your Toyota dealer of choice
Old 04-05-2018, 02:54 AM
jbslash25's Avatar
Name of seal
Thanks for the help this is the 1st time I've ever gone on a forum. Thank you also for not making my question seem stupid. Toyota owners are good people.
Anyways I've been trying to locate this seal that is on the inside of the on the inner side inside the inner bearing seal. Haven't had time to go to Toyota, but every part store x2 where I live don't have it or they try to say it's the inner bearing seal. Even after showing them the seal which is clearly a different diameter. Let me get a picture up and show you where I'm stuck at
Old 04-05-2018, 07:35 AM
akwheeler's Avatar
Are you referring to the rear wheel bearings or the front? It sounds like the front.
Please add a signature line to your profile listing your make model engine and transmission type. It will save a lot of time and silly questions on other topics.
greasyglue
04-26-2017 11:44 AM
Neemox
04-09-2017 07:12 PM
wilshire
03-31-2017 06:46 AM
95Runner
06-09-2002 08:56 AM
Vato Loco
06-05-2002 03:58 AM
Quick Reply: 95 2nd gen wheel bearings ?
