92 Toyota 22re idle up vavle
https://cimg9.ibsrv.net/gimg/www.yot...b14ccc14a0.jpgI'm having high idle problems I've noticed on other post that the idle up vavle has a screw where mine has a cap should mine have a screw and it is broke?
Unless something is broke allowing air to be pulled in or that cap is dry rotted and cracked .
It should be fine. It has been quite some time since I looked at a 22re of that year . That valve just looks different then the mid eighties engines I have no doubt a upgrade of some sort . Just what is under the cap?? |
Should be a spring around that port that your cap is covering and a bolt through it compressing the spring. Bet you can find those two parts super easy in a salvage yard for little of nothing.
I am very familiar with that particular cap. When I did some modifications to my engine, i needed to use a bunch of caps. Some of the caps were thick, black rubber and I bought them in individual sizes. I also ended up buying some of those type of caps because I couldn't find the black ones in the right size at the particular store I was at. The black rubber ones are still doing fine. All of the ones like the one in your picture failed within 6 months. You are going to need to do something about that cap pretty soon. |
Any idea what this part is called?
| All times are GMT -8. The time now is 12:38 PM. |
