91 toyota Gearing help
I have a 91 Toyota pickup with a strait axle front conversion also with a 6" suspension and a 4" Body lift on 33x12.5 Bf allterain's and 15x14.5 rims. i'm wondering if anyone know's a good place to purchase gearing im looking at going with 5.29's.
Thank you Help Appreciated! |
Welcome to Yotatech. :D
:wabbit2: |
^ there ya go! that sounds like quite a lift for 33s haha,
[quote=waskillywabbit;51731705]Welcome to Yotatech. :D
thanks! |
BoredOutnJackdUp^ there ya go! that sounds like quite a lift for 33s haha,
Yeah its all i can really run at the time. my truck has a hard time pulling this setup already. That is why i am looking for a good place to pick up some gearing. Do you know of any place's? |
Thanks For the info!
With that much lift i would go with 5.29s it will give you room to grow in the future if you step up to 35s or decide to go even bigger.
Originally Posted by cbr600rx7
(Post 51731825)
www.gearinstalls.com is a great place to get educated on it.
how big of tires are you wanting? and what motor do you have? and he states in his 1st post he wants 529s. |
Originally Posted by BoredOutnJackdUp
(Post 51732139)
Thought 4" body lifts were illegal?
Post a pic of this thing. Personally I would pull the bodylift. With 6" you can clear 36's 5.29's and 35's are the perfect match |
Originally Posted by ocdropzone
(Post 51732430)
Why a 12.5" wide tire on a 14.5" wide wheel? 10" wide max
or a 12.5 tire on an 8in. wheel is a poor mans bead lock
The rims and tires came together that way. They were free so can't complain. I'm changing everything as I go along.
:pics:
k this is the real specs for my 91 toy.
- Front end conversion to strait axel. -full rebuilt 22re -15x12 Dick Cepek DC-1 Wheels. -33x12.5 bf all terrains -6" suspension with 3" body. this is the real specs on my truck i had my friend post the prior posting's so that is why there was mix up's. What i'm looking to do - Gearing "Prefer 529's" whatever is better for highway/off road use. - Going up to 35in Tires. Thing's in the future - Pulling intake manifold and transferring over to carb. |
Picture's will be up soon...........
Why are you switching to a carb? Most guys try to go the other way. What tranny are you running? My auto can boogie on the freeway with 5.29's but 4Lo is still pretty low. 5.29's and 35's with a manual would be perfect. I would definately address that tire/wheel situation, like Ocdropzone said, 10" wide wheel max for a 12.5" tire. With your current setup the rim is going to be wider than your tread.
