YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   87 22re timing (https://www.yotatech.com/forums/f120/87-22re-timing-305033/)
Kejv 07-13-2018 06:34 AM
87 22re timing
Heey so I'm from Hungary I have a little broke english. I lI've in grants pass oregon. I got 87 22re pickup 7k miles in the rebuild. So I have cold start issues but after starts if I didn't give gas for the car it's almost die. I lose a lot a power too I'm not really able to Cruz uphill just in 3rd in like 35 40 mph... Question what is really going on?
junk4u 07-13-2018 07:09 AM
Timing, TPS (throttle position sensor)... check compression after rebuild? check fuel pressure, regulator, etc...
Kejv 07-18-2018 09:22 PM
I turn
so I turn 180 on the engine put on compression stroke touch top cylinder put distibutor on #1 and put together n adjust the timing with light. Still no power. That not true my engine runnin sounds right the weird ticking is gone and a little better power on low rpm.. but there ia feel like not right still. Im goin uphill 40 in 3rd.. i know my throwout bearing is start to wining not too long ago. I have the new one its just a pain to do it. There is eny effect by that maybe..? What next guys?
