82 toy headlight problem
the headlights wont turn on. everything else will work and the fuse is good. what do i do and how do i do it?
Headlight relay perhaps, under hood typically. And headlight bulbs otherwise OK and plugged in? Do you get anything in flash mode (pull back on dimmer switch)?
No nothing in pull back they won't come on at all and where is the relay located exactly ?
Usually the fuse/relay box under the hood, at least that is where it is at on my '85:
- http://www.4crawler.com/4x4/4R_TechI...tml#Electrical |
