82 pickup
2 Attachment(s)
welpp i gotta 82 22r pickup.replaced the carb. fuel pump, and filter, and oil. well now itll start fine in the morning or a slap cold start. whenever it warms up though it'll cut off like you turned it off. i saw that whenever i pushed the gas whenever it stalled. some smoke will come out, is this normal? if not how do i fix it. the BVSV near the fuel pump broke off, how important is that? also found one end of a metal pipe that comes mounted to the carb, the end on the passenger is not connected to anything and no hoses are round it that aint connected either. that normal?
oww my nose...... can we get some bigger pictures of what you want us to identify for you? And No. Smoke is not normal.
idk how to get it bigger, i was thinking that whenever it stalled all the gas ran out of the carb
get yourself a photobucket account and upload your photos from your camera there, just make sure your camera is set to a higher resolution like 1080 X 768 roughly 1 megapixel. Or you take take larger photos and have photobucket automatically adjust the size to 1024 X 768 in it's setting like I do.
then you can post the IMG link that photobucket gives you here into the message. |
