82 Frame on a 84 Truck
Will a frame for a 82 Toyota work for my 84 toyota truck.?
My farme is shot, found a great 82 frame and chassie, just want to make sure it will fit. Thank you |
I'm pretty sure that the frame for an 84 is wider than the first gens
i think the axle width is the same, but the wheelbase is longer on the 84 iirc.
the body is wider also. you will need to use a driveshaft for the 84. research(google) wheelbase on the two trucks. http://home.4x4wire.com/erik/diffs/ better get a tape measure. |
