79 toyota vacuum advance distributor 180 out
I'm building up my toy and decided i wanted power steering but i run into the vacuum advance with the bracket. i modified the bracket to make my vacuum advance clear then found out the pump runs into the vacuum advance since it is on the bottom of the distributor. My question is if i rotate my dist. 180 out then flip all spark plug leads will my motor run smooth. my thoughts are to flip 1 and 4, 2 and 3 so they would be 180 out and make a custom bracket for the adjustment making my vacuum advance sit on top.
icentropy
07-11-2015 07:21 AM
