3rd members
I have a 87 toyota pickup with the 22re and i need a new 3rd member with the 4.10 gear, what other years are the same as mine ? are they the same in 4runners ? dose it matter if the donor truck had a 6cyl ? and whats a fair price for a used one ? is there anything to watch out for when buying a used one ? thanks
This is a good source for that stuff
http://home.4x4wire.com/erik/diffs/ But you really should try a search before posting a simple question. Just sayin , :con: |
thanks ! so how can you tell if the bearing is bad and whats a fair price ?
Well you can buy a new one with any gear ratio you want and an arb locker installed in it for about $1200. So a stock 4.11 3rd with god nows how many miles on it shouldnt be more then a few hundred clams.
As far as bad bearings go its pretty uncommon. But id check the 3rd by hand to feel for roughness when it spins or anything obvious, other then that theres not much you can do. And obviously visually inspect the gears. |
Originally Posted by Beardog80
(Post 51970746)
| All times are GMT -8. The time now is 07:31 AM. |
