3rd Gen 4runner Rearview Mirror Upgrade!
4 Attachment(s)
Hello oh powerful Yota-Tech!
I'm contributing about some fantastic 'junk-yard' mod that I'd looked for on here (without using the right key/search words, of course) and didn't find anything on... so, here's my write up on how to swap your 2wd/4wd 89-95 Toyota Pickup truck rearview mirror dome light out for a fantastic directional 'Map Light' 4runner dome light! NOTE: here's a thread I found with Superbleeder/Aviator in it, with confirmation that it works, so don't just take it from me and my pics! https://www.yotatech.com/forums/f116...unners-180390/ So, STEP 1:Attachment 201638 Get yourself a 4runner dome mirror (and a sexy center console, if you're into it!) STEP 2: Attachment 201639 Tools Needed: Single Philips Head WIDE tip screwdriver! Single Exacto Knife / Utility Knife STEP 3: Attachment 201640 Take the Cover off your old Rear View, remove the 3 screws there. STEP 4: Attachment 201641 Using the NEW Housing, press (gently) into the headliner the shape of the two new Mirror's light housing. While the imprint is fresh, cut the holes with an Exacto/Utility knife. Repeat this process for the *two far screw holes* on the 4runner housing (The threads should be there, in your cab roof) Connect the wire, tighten down! Step 5: http://i23.photobucket.com/albums/b3...h/DSC00731.jpg Attach the cover of the lights, and test! It should be all working just fine! NOTE: When you pull the cover of the 4runner mirror, MAKE SURE you get the *two far screws*. These are COURSE thread screws, and need to be installed in the far screw location! Now, you've got an awesome directional light and rearview mirror! -Big Ups and Love from Santa Cruz!:fire2: |
