2nd gen 4runner Frame Rust
9 Attachment(s)
I bought this 94 4runner a few months ago for about 1200. 155000 miles.My other car caught fire so I was in a hurry to get something. In my foolishness I bought it without inspecting the underneath. They said it just had a bad water pump so it seemed like a good deal. Which was a complete lie. Ball joints were shot along with cv axles and brakes all around. I have all new parts in that aspect just sitting at the house. Brake drums, shoes,rotors, pads, upper and lower ball joints, inner and outer tie rods, tie rod adjusting sleeves, idler arm, pitman arm, cv axles. So quite a plethora of new parts . Having all these fresh parts to put on is the least of my worries. After knocking atleast 20lbs of rust scaling off the frame and looking for weak spots I have found several. Is it worth repairing.? The whole frame is rusty and worries me. Ive already poured alot of money into this 4runner and its been nothing but a headache due to used car place that sold it to me( they shut down due to shady practices before I got my title) and a mechanic that ripped me off as well. Im really trying to stay positive about this but its hard not to feel like its a losing battle everytime I crawl underneath and the frame seems worse than before.
that's a sad story, but what exactly are you asking?
whether you should bother putting the new parts on? not enough info to answer that... i.e., is the engine using oil? clutch or auto, does it shift well? how much have you put into the truck, minus the spare parts that aren't installed? etc. |
Originally Posted by osv
(Post 52335696)
Well your frame needs repaired .
If you can do the work your ok if you need to pay labor rate it can get expensive . Either use this one as a parts vehicle and hunt for a 94 in better shape Sell it as it is and cut your losses Not being up close and in person paying to have that repaired the right way you will now have another $2000.00 invested best guess Did you not check anything before you bought it?? It is 22 years old Just where are you at ?? Did this see 22 years of Northern Winters ?? A real shame to see a neglected Toyota My parts trucks are in better shape Let the buyer beware is more true today then ever. |
the frame is toast, not worth attempting to fix, imho, and the body of the truck isn't worth swapping onto another frame... you could pick up a dry 4runner out west for much less hassle than flailing around with that junk.
put the engine back together and drive it around, see exactly what you got for a drivetrain... if it's solid, you might be able to use it to swap or for parts, like wyoming says... although it's got the 3.0? the upside is that this will be a good learning experience, and you'll get to know the truck pretty well. |
Originally Posted by wyoming9
(Post 52335704)
If you can do the work your ok if you need to pay labor rate it can get expensive . Either use this one as a parts vehicle and hunt for a 94 in better shape Sell it as it is and cut your losses Not being up close and in person paying to have that repaired the right way you will now have another $2000.00 invested best guess Did you not check anything before you bought it?? It is 22 years old Just where are you at ?? Did this see 22 years of Northern Winters ?? A real shame to see a neglected Toyota My parts trucks are in better shape Let the buyer beware is more true today then ever. Thanks for everyones input. I was kind of leaning towards the same thing. Im in WV and they do salt the roads here. It has been a learning experience all around. Take my time and inspect more in depth to avoid costly mistakes in the future. On a positive note I have become alot more familar with these toyotas. |
You got screwed, cut your losses and start over, part that one out.
Nothing is to bad it can not be repaired the question is weather it is cost effective !!
This is a example of new vehicle lust one is so excited I am not sure where the blood goes it is sure not the brain. It tends to get us all at least once . This is quite common for a vehicle this old in this part of the country sometimes we forget people for the most just get in the vehicle and drive change the oil once a year or just add fluids as needed That body is in better shape then all of mine osv you must have high standards *** |
(Post 52335752)
hindsite is 20/20
this thread highlights an important lesson: unless you want to get ripped off you need to be very thorough inspecting any vehicle you plan to buy. Some auto shops will perform a free buyer's survey and let you know if they find anything wrong in the hopes that you will buy the vehicle and bring it to them for repairs. you can then use this information to negotiate a lower price. it the vehicle is coming from a used car dealer do not take their word for anything, test drive it to another shop for a once over. I have worked as a mechanic at stealerships used car dealers and independent shops/tire shops and can tell lots of horror stories, trust me on this, if you don't do everything yourself find a good mechanic at an independent shop and stick with him, ask the shop to make sure he is the one working on your rig, if he quits to move to another shop follow him. once you find a good and trustworthy tech don't let go!
