YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   22rte troubles (https://www.yotatech.com/forums/f120/22rte-troubles-289748/)
karbin Jul 5, 2015 09:53 PM
22rte troubles
Alright guys I'm new to this whole forum thing I usually just look for answers on these sights but I'm at a total loss now and nothing seems to help to start off I have a 1986 22rte turbo truck 5 speed I recently did a sas and now it's setting on 37s when I first bought the truck the motor was in the bed cause the turbo was destroyed I bought everything to rebuild the entire motor from engnbldr including a new turbo and when I fished the rebuild it started right up I had a few problems here and there like injectors were clogged so I bought new injectors new sensor and so on but now it doesn't wanna run at all I know these for sure it's getting fuel it's getting spark and air the thing turns over and over and sometimes try to hit but nothing if u hold the gas peddle down it'll try to start and if it does it runs like junk and it smells like it's flooded afterwards any suggestion would be very helpful and I appreciate your time reading this book lol but please let me know what you guys think
Thank in advance
wyoming9 Jul 5, 2015 11:37 PM
Did you also replace your cold start injector with the other injectors.
There could be dirt in the injector allowing more fuel then should be flowing into the manifold.
I would think all the other tune up parts are new.
Fresh gas as well??
What condition was the fuel tank in now that it ran for some time all the dirt is in the fuel filter or the sock on the pump.
Air intake system in good shape no leaks or cracks??:wrench:
Some ideas !
