22RE Ebay Water Pumps
I see there are quite a few water pumps on E-bay for the 22RE ranging from $18-$40 (all are said to be new). Are any of these any good? Any I should stay away from?
Don't expect those water pumps to last nearly as long as OEM. As long as you understand this dynamic, then you should be fine. Expect to change them in 25 - 40K miles. I would not let it go longer than that.
Or replace with OEM, which is more expensive, but will last in the 90K range. Your call. Pay once or pay twice down the road, but it all depends on what your doing with the truck. |
Check out www.partsgeek.com and you may be able to pick up a AISIN WP in the $50-70 range....same pump as from the dealer, but typically less expensive.
Or Toyota of Dallas (among other online Toyota dealers): http://www.toyotapartsales.com/partl...?siteid=214074 |
www. autohausaz.com aisin water pump 52.96 free shipping over 50buks it will b there n 2 days.
Good deal.... I always forget about autohausaz. :)
