YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   1992 headlight (https://www.yotatech.com/forums/f120/1992-headlight-316957/)
heatherhh Mar 22, 2023 08:51 AM
1992 headlight
Hello, I have a 1992 toyota truck. It doesn't have any wires for the driver side headlights. The passenger side is fine. Can I splice into the passenger wiring to run wires to the driver side? I've only had the truck a couple months so I don't know why there are no wires,
Discombobulated Mar 22, 2023 09:07 AM
Are you 100% sure the wires are gone or cut? Maybe they got stuffed behind the headlight housing, I’m trying to remember but it should be coming out of the same harness that goes to the running lights and the signals in the front……
Steel_Beans Mar 28, 2023 04:59 PM
Its possible your truck has custom aftermarket lights on it. Are the lights that you have on it right now the factory lights or are they aftermarket?
jeremy harp Jun 7, 2023 07:06 AM
How did u work it out ?
