'04 Tacoma V6 5VZ-FE Timing belt replacement help
I have an '04 Tacoma V6 5VZ-FE with a timing belt Is it the same procedure for removing the belt as it is for the chain in the manual? I also plan to change the pump at the same time. Anything else I need to know? Thanks!
Longtime Toyota LOVER |
tacoma 2004 belts and pumps
Just bought an 04' Tacoma TRD 4x4 V6. I need to change the belts, water pump, and what ever else I see when I'm in there. Does anyone have any suggestions on brands of the parts? What else should I order to make my truck last longer? Plan on having it for the next ten years.
Thanks. |
This Link to Toyota Factory Service manuals will have the procedures you need.
Advice on parts-a lot of people say to stick with factory parts. Make you truck last longer: regular/preventive maintenance, keep your tires rotated balanced, don't abuse it... |
i went by this http://www.4x4wire.com/toyota/maintenance/timing_belt/
and got this kit very good parts http://cgi.ebay.com/ebaymotors/Timin...Q5fAccessories |
Thanks. Found a bunch of info on tacomaworld also. No one has mentioned anything about brands yet. Figured factory parts are the best if no one is complaining about them anyway.
I have an 84' and 86' also. I like working on my own vehicles because I have peace of mind that way. Having other people do the job is more money, but more importantly, I don't know exact workmanship they put into it. Thanks again. |
There are no "brands". B/c factory parts have the highest quality and QC.
You can get any brands at your local PepO'RileyAutoAdvanced, but take about +/- 20,000 miles off the factory advised service intervals. No cheap-o China WP will outlast a Made in Japan to Japanese specifications, Aisin WP. |
