ISO 01' stock intake/box + BCM
Dropped my intake and cracked the air-box inside the filtered area, also have dry rotted/cracked rubber T-body coupling that is going to leak air soon so need these parts of the intake.
Also need a Body Control Module after getting mine a little wet in a mud-hole (water came up to steering wheel and got it wet). I need the non VATS/chip key BCM part number 82730-35310, comes out of the kick panel above left knee along with fuse box. Not super critical, was going to get parts together to fix it this spring. I'll probably hit a junkyard if no one has the BCM but I've had good luck finding parts here. -Tom |
Bumpp
Bumppp
