3VZE Heads
Looking to buy both left and right heads! If local great if not then area code is 12553. Truck is 1994. Thanks
I'll have 3 3.0s pulled over the next month or so.
How big a hurry you in? :wabbit2: |
Wabbit, I will be searching hardcore for a set after the 29th of this month.
I've got a motor from either a 93 or 94 v6. I bought it for parts last year and it's been sitting since then. missing injectors intake and pulleys. I'll let it go really cheap if you want it. I'm from the Albany NY area.
Have you ever done a compression or leak down test on it? Do you know many miles are on it?
It's supposed to have a bad head gasket. I picked it up local when my head gasket went but ended up using my motor. Guy said it had 69,000. But who knows. I'll try and take some photos for you I won't be home til Sunday. If you want it you can have it for $75
The whole thing for $75? If so I'll take it. I'd have to come up on a weekday after 5 though.
That's fine pm me and I'll give you my number
PM sent, thanks
| All times are GMT -8. The time now is 05:48 AM. |
