06 4Runner vibration/noise
Old Mar 24, 2016 | 09:13 AM
rquick643's Avatar
I have a rhythmic hum/growling noise and can feel a slight vibration in the drivers side floorboard. This only happens at speeds above 60 mph. This started after both cv axles were replaced. One shop said wheel bearing going bad but I'm not convinced. 2006 4wd SR5 160k miles.
Old Sep 10, 2016 | 07:56 PM
Winkel's Avatar
Do a search on the front differential needle bearing/bushing replacement. East Coast Gear Supply makes the bushing.
That may be the culprit. Mine started when I installed a spacer lift. I noticed it when I finished the front but hadn't yet done the rear.
If your U-joints are all ok and neither of your front hubs are hotter than the other after driving for a while, I'd give this some serious consideration.
punks_is_4x4
Mar 4, 2016 09:35 PM
80seriesftw
Feb 23, 2016 11:27 AM
jsindorf
Feb 21, 2016 09:41 AM
greasyglue
Jan 29, 2016 06:05 AM
deadstock
Jan 24, 2016 05:46 PM
