ZUK Mod - No Cut - 96-98 Runner Coil Springs
#41
...might be. dlucky894runner just ordered those coils so let's see what he finds.
https://www.yotatech.com/forums/f116...ptions-235742/
Is there a 4x4 lift shop near you? They might have some stock front TJ coils that they will give you free or a small charge. They always end up in the dumpster behind the shops
no....but as long as I know what years I'm looking for.....and yes, I want to see how dlucky makes out.
#42
Jerry TJ's were made from 1997–2006. Pretty sure the coils are the same, whAT I am not sure is if there is a difference between the rubicons and unlimiteds. I wanna say the rubi's sat higher, but not sure and also not sure if it was suspension or body lift if that's the case.
this might help: I think it confirms they are all the same: http://www.quadratec.com/products/16190_006_07.htm
#43
thanks Brandon......for new ones almost the same as used ones, and if these are the right size.....no cutting of either the spring, or the vehicle
https://www.yotatech.com/forums/f116...Q5fCarQ5fParts
#44
if you can confirm the TJ coils work check on the rausch creek forum and put up a wanted ad, I am sure someone would be willing to give/sell you a set. Not sure if they would be any cheaper the those BM springs. I have been following that other thread as well.
#45
I'm using front TJ springs from a 97-06 TJ, cut down to 12" from 14". No complaints whatsoever. I got a pair off ebay for around $40, but you can probably find them cheaper locally.
#47
thanks for the info, good to know for other members doing similar set up
a member on here hooked me up with a 22inch brake line for free
my setup: ~2inch lift from stock high (~3 if measuring from sag)
96-98 rear 4runner coil springs
OME N94 Shocks
DIY Bracket for LPSV
22inch rear brake line
32x11.5x15
will be adding 1.25 inch wheel spacers. when i was all twisted up this weekend, i can hear the springs slightly rubbing but under normal driving there is no rubbing.
so the jumping i get when taking off (just letting of the brakes) feels like what some guys call axle wrap. not sure if thats what im getting. its odd. it only happens if i come to a stop kinda hard. usually im light on my brakes to a stop. if i stop hard and bout to take off. i let of the brakes and the truck kinda jumps. like the drive train is loaded. i was driving around is circles with my head out looking at the rear axle, i can see when i brake. the axle front drips down and back up lol
#48
#49
So, it looks like the 13" coil will give 2 15/16" (3").....Looking forward to future updates and if the sag of the coils will even be measurable. You certainly took some clear close-ups.
The 16" coil is 3" longer but will likely give about 2/3's of that so probably 4.5" to 5" lift......hmmm. That 16 incher sounds like a great option for those that have a 4" block and want to ditch them with some lift. At about 5" of lift the coils are supporting ALL of the weight I estimate. That means the leafpacks are getting easy duty and simply locating the axle left/right/forward/backward....the leafpack also prevents the axle wrapping.
I'm home sick as a dog today so I have time to make some links
Now it's 92TOY's turn to do it.....
ZUK
ps---I'm thinking that those concerned about the lower coil fit around the rubber snubber...and the way the coil is strongly contacting the u-bolts, can force 1 or 2 pieces of 8" long heater hose on the coil lower end. Also, maybe some cheap hardware store steel brackets under the u-bolts and positioned just right could help locate/limit the coil moving around. Just some ideas.
#50
oh ya....options options...the 5" OD coils from ebay.....
...come in 13"
http://cgi.ebay.com/ebaymotors/NEW-R...Q5fCarQ5fParts
....or in 16" length
....and they come in a yet softer 100 lb/inch rating also. Too many choices...
...come in 13"
#52
Alright, so... I've read through probably 5-6 ZUK mod threads, and I still have the same question... Maybe I'm just slow, but here it is:
What Make/ Year/ Size of springs would be completely cutless and weldless on a 91 pickup?
I need to get rid of 2-3" of sag to even out the stance, if that makes any difference.
Thanks to anyone that knows the answer.
#54
good question. ill try to get some pictures. its the best mod i have so far!!
#56
#57
#59
Vargntucson
07-04-2015 12:15 PM
