Wire going into rear 3rd on 1991
What's the wire plugged into the rear diff on my 91 4x4? My 82 doesn't have one. Sorry if it's a dumb question.
That makes sense now. I was getting ready to swap axles, because my 82 has an ifs rear and both axles in that truck is locked up with 5.29s. Was thinking of throwing the built axles under the 3rd gen. Now the real question, should I just swap axles and disconnect the ABS, or try and load my gears in the 3rd Gen housing? Would that be too hard for the results?
Can't regear 4.88 w/ anything other than 4.88: https://www.yotatech.com/forums/f116...22/#post857235
Okay, you can't swap the gears into your current third member, but you can swap third members between your axles -- I think: https://www.yotatech.com/forums/f116.../#post51209951
Sorry, I have the 4.88s and am keeping my 31 tires. Just tyring to help.
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
RSR, his 91 didn't come with 4.88's. OP, you can put the rear 3rd member from the '82 into the '91. But you can't put the front 3rd member of the '82 into the the '91. The IFS diff is smaller than the straight axle diff, so you will have to have the '91's front diff re-geared.
I think I'll just swap the full setup front and rear and tie up that ABS sensor out of the way. I really appreciate all your input. Makes life a little easier when you can ask a hundred people the same question.
ahhhhh, you didn't mention the '91 bein SAS'd.....lol. No worries, as I said before, there are no dumb questions here.....
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
